Etabs Results
Muhammad Abbas
is there any difference between the result generated by cracked Etabs and original licensed Etabs?
What we used to do in our firm was to model a simple 4 column structure and check loading manually before shifting to a new etabs version. You many find different cracks by different people for same etabs version. Some do it right, others dont. Just run a simple model check & remember softwares can never replace judgement.
apart from ETABS remember that i used some softwares where they have written in manual that the limited version contains random errors so dont use it for design so if some one cracks that it will too generate errors..just dont blindly download any tool and start looking for crack and the use...pls read manual first..
but for ETABS i didnt find anything like that
