Water Testing Structure
abdulqadeer29
i have to design a water testing structure ....height of this structure is about 50 feet...this structure will be surrounded by RCC walls ...now internally these RCC walls have to resist water pressure and also resist earthquake as well...now i am confused that how to tackle it...i can design walls manually to resist water pressure but i require your suggestion that which software is available in which i can apply water pressure to walls ???
etab is not good in handling water body structure as far my knowledge is concern, so need your guidance???
from water structure what you mean is it a wier? or some model of any dam?it is better to calculate the manual hydrostatic pressure also earthquake forces and you can laso model it in etabs
@AQ, SAP has a template for water tanks. You can do it manually too using above quoted document. What load combos are you planning to use? You won't have 100% live with earthquake. FYI; In water tanks, sloshing acts to dampen vibrations of the water tank in an earthquake.
yara it is just lyk water tank .....but purpose is different...
sir umer , any software whch vl be helpful or i have to do it manually for both earthquake forces and water pressure???
Is your issue resolved ?
not yet...i am wating for soil report so yet not started on this project...and still  i am also finding out time to cover material which sir umer recommend me.....if you have any sugssion please provide me that as well....
Do check your water tank for overturning moment @ base.
yup i will..
by the way do you have any idea how to check structure safe against over turning moment???
Draw a free body diagram and that will answer your question.
