Design Of Sloping Roof In Etabs & Assigning Earth Pressure In Basement Wall
fazalarju
help saught in following
(i) whether sloping roof can be analysised as hz roof in EYABS( without assigning diaphargm)
(ii) I have found no option for applying load varying linearly in surface loading. then how can one assign earth pressure in RCC wall in basement in ETABS.
Please comment . Thanking in advance.
Sir,
(i) Perhaps there is some confusion  regardig my posting. I meant whether sloping slab can be applied usual DL and Live load over it in as in the case of RCC hz floor in Etabs. whether load on the sloping floor (assigned as" membrae/shell")will transfer to the related beam. I am cnfirm that this sloping floor canot be assigned Diaphargm.
(ii) Regarding basement wall, It is well known that the RCC wall can be modelled as wall(as shear wall) but how the lateral load of earth pressure(active) of which nature is linearly varying  are assigned in those wall as there is no provision of assigning linearly varying surface load in Etabs). whether this can be applied aas per my attached file.
Views from expert  member from this esteemed forum is requested.
Thaking in advance
eart pressure in basement wall.docx
Dear Fazalarju, even though you have requested an answer from someone else, I feel, I should reply again.
The answer to the first part of your question is 'yes'. It was yes in earlier comment; May be, my earlier reply was not lucid enough.
Regarding second question, I would say that the assumption, inherent in your query, is so rigid that you are not able to comprehend the answer to the contrary.
I understand your query, and I am aware of the distribution of earth pressure.
Thank you sir.
I unsertood that earth pressure(Hz lateral load canot be applied directly).The software(ETABS) has the drawback of applying surfacece load of linearly varying  but it should be analysised separately and to be applied mannualy. Moreover if there exist 2 to 3 basement it will be much labourious also.Please correct me, If I am wrong in understanding .If there is any alternate  procedure please brief .
Etab is for frame analysis, for basement walls you have to follow procedure of retaining walls , in most of the cases when your wall is attached with slabs at each floor , behavior of wall also vary as like beam with pin support at various points.....
Applying earth pressure in Basement in ETABS
Can we apply earth pressure as follows.
1)Auto mesh the walls suitably
2) Dummy columns named DUMMYCOLUMNS are provided at locations that
match the auto-mesh of the walls
3) Dummy columns are given sections of 1X1 cm^2, to act only as load-transferors
4) Loads are provided in 'DEAD' case. But better create a separate
case like 'SOILPRESS' for it
5) Loads are provided on the dummy columns and side columns in
direction of local axis that match the direction of actual soil
pressure – negative in local-2 direction, in this case.
Expert comment is saught in this regard.
  • 7 months later...
For Applying loads on Basement wall this could also be done in SAP but ETABs has limitation of this ...It would be better if u design the Basement Walls using spread sheets of a very easy software named as QuickRWall
  • 8 years later...
  • 7 months later...
On 12/3/2013 at 8:47 PM, fazalarju said:
Thank you sir.
I unsertood that earth pressure(Hz lateral load canot be applied directly).The software(ETABS) has the drawback of applying surfacece load of linearly varying  but it should be analysised separately and to be applied mannualy. Moreover if there exist roofing company Bloomington 2 to 3 basement it will be much labourious also.Please correct me, If I am wrong in understanding .If there is any alternate  procedure please brief .
