Member Force Diagram For Frame Element In Etabs
Zoya Hassan
I have problem understanding the concept of member force diagram for frame elements....
when i select moment 3-3 component then it shows the moment diagram in 2-2 axis... and similarly for moment 2-2 which it shows in local 3-3 axis.... so when i select moment 3-3 etabs displays the moment diagram in 2-2 direction i-e i will bend in local 2-2 axis but selecting 3-3 should show bending along 3-3 axis... also 3-3 moment is maximum... any body can help me in this regard may be i got confused with this terminology but i searched alot on this...
Yes,
Moment 3-3 means beam or frame is bending ABOUT 3-3 axis. Dont worry how the bending moment diagram is forming, thats just text. In 2-d plane, the max peak moment will be in the direction of local 2-2 axis but actually your frame bends in 3-3.
