Tension Only Bracing Cables In Sap2000
Waqas Haider
Tension-only elements in ETABS
Tension-only elements can be modeled using the nonlinear version of ETABS. The process is as follows:
Select the elements to be specified as tension-only.
Specify the tension limit (usually a limit higher than expected maximum tension capacity) and a compression limit of zero (or negative) through Assign > Frame/Line > Tension/Compression Limits.
Run a nonlinear static or nonlinear time-history analysis. This is necessary since tension-only assignment is a nonlinear feature.
Any load case or combination may be converted to a nonlinear analysis as follows:
Select the case(s) through Define > Convert Combos to Nonlinear Cases.
Run a static-linear analysis, then once complete, run a static-nonlinear analysis (only required in V9, in V13 linear and nonlinear cases will run at once)
Add the nonlinear case(s) to a user-defined combination with a scale factor of 1.0.
Apply the nonlinear combination as design load.
Perform design.
When full nonlinear behavior must be considered, nonlinear time-history analysis should be run since response-spectrum analysis only applies to linear systems. Further, response-spectrum loads cannot be converted to nonlinear cases.
Source: https://wiki.csiamerica.com/m/view-rendered-page.action?spaceKey=etabs&title=Tension-only+elements+in+ETABS
Also see: https://wiki.csiamerica.com/m/view-rendered-page.action?spaceKey=kb&title=Tension+and+compression+limits+tips
I just noticed that you are asking about tension only "cables". I havent used cables in Sap2000 but they should never take compression.
Please see the tutorial at CSI webpage to see how to define tension only bracing. I am not sure if the tutorial covers cables but cables by default should be tension only.
http://www.csiamerica.com/content/sap2000-09-tension-only-bracing-watch-learn
