Stability Checks In Safe Software
Waqas Haider
Assalam o alaikum.
Kindly tell me whether SAFE has capability to do stability checks especially Sliding check and Overturning Check? Is yes then How? I model footing in safe and when i provide horizontal forces, my footing gets slide. Jazak Allah.
  • 5 years later...
On ‎12‎/‎31‎/‎2014 at 7:42 AM, UmarMakhzumi said:
W.salaam.
Assuming that the heading on the link below refers to a version of Safe, the Non-Liner Version would do. Which version do you have? See the link below for complete features:
http://www.comp-engineering.com/products/SAFE/analysis.html
salamu allekom
Dear Umar
please tell me how can I do the stability checks (sliding and overturning ) in the SAFE for combined footing , I checked the above link but it's not working. appreciate your support.
@Hussam Afifyyou can manually apply the overturning check,  multiply horizontal load (either from wind or seismic) with the distance from the bottom of the footing to get your overturning moment, and then check against the stabilizing moment i.e (weight of the structure + soil above footing multiplied with their respective lever arms.
On 6/30/2020 at 4:29 PM, Hussam Afify said:
salamu allekom
Dear Umar
For Sliding, you can consider friction between footing base and soil. Friction coefficient is normally 0.5 but varies from code to code.
