Pin Support Or Fixed Support
Waqas Haider
Assalam o alaikum all,
How to decide what type of support should i provide at base of my building in ETABS?? If I provide pin support then sway of my building is 1.5 in and if i provide fix support then sway reduces to 0.9 in. Some one in this forum replied to a thread (I am unable to find the same thread) that if soil is stiff then we can provide fix support other wise pin support for loose soil. But I think it is upto our will then whether we provide fixed or hinged, sizes of our footings will become accordingly. In my case, building is in Quetta with BC 0.75 tsf. Suggest me please.
W.salaam.
Since we normally don't consider soil structure interaction in structural analysis, therefore I am quite certain that the statement quoted by you about choice of pin or fixed based on soil type is flawed. Anyhow, for concrete columns unless special detailing is done at coulmn joints, they would always transfer moment that should be accounted in the design. Using fixed based would likely result in conservative design for structural members than using pinned base. The real response would stand somewhere inbetween a pin and fixed base.
As Umar said the real response would stand somewhere in between a pin and fixed base, similarly extent of column fixity at base depends upon the rotational flexibility of foundation that depends on foundation stiffness and soil stiffness both.
In general it can be said that for rigid raft foundations,foundation supported on stiff piles or basement walls this rotational stiffness is high and one can confidently assume fixity of column at base.
But in conditions of individual footing pads on deformable soil,foundation could have considerable rotational flexibility and consequently assumption of fixed column base could show a considerable variance with respect to distribution of column moments on bottom storey i.e in such case column moments could be concentrated at top end of bottom most column rather than at base.
Therefore, It is recommended to model the rotational stiffness of foundation rather than assuming fixity at base in cases of individual column pads on deformable soil to represent quite realistic partial fixity available at column base.This methodology can be seen in "Seismic design of reinforced concrete and masonary building by M.J.N Priestley" (page 466).
Assalam-o-alaikum!
"Therefore, It is recommended to model the rotational stiffness of foundation rather than assuming fixity at base in cases of individual column pads on deformable soil to represent quite realistic partial fixity available at column base.This methodology can be seen in "Seismic design of reinforced concrete and masonary building by M.J.N Priestley" (page 466)."
Umair!
Assuming that you are referring to the book by 'T. Paulay and M.J.N. Priestley, copyright 1992 by John Wiley and Sons', can you indicate exact reference to the chapter and article or example number, in which this methodology has been explained?
I have myself tried to locate the content on your referred page in the above book, but was unable to find it.
On 1/7/2015 at 1:02 AM, Syed Umair Haider said:
See chapter "foundation structures" topic foundation structures for frames.
Thank you Syed for providing us with this great reference. I reviewed the book and found out that the footings are best modelled assuming a rotational spring with a stiffness of (Kf) where:
Kf = (ks)x(If)
Can you please help me in calculating the value of (If) with an example? I don't know how to calculate it.
Thank you in advance!
