Conflict In Analysis And Design Results
abdulqadeer29
I am working on a building with quite high loading.
live load :300 psf
Super Dead :90 Psf
The problem in my etabs result are quite unusual for me.I got more reinforcement in bottom as compared to negative in  continuous beams.
In the analysis, moment diagram is not showing such irregularity. need help form seniors.
Are you sure, design results are from STRCOMBO2 (the same combination you are showing moments on)
reinforcement is also affected by seismic detailing requirements. check in code what seismic category you are putting.
It is something due to excess loading. i have reduced live load to 50 psf and i got a normal pattern of reinforcement. the only option i have is to use the analysis results and calculate reinforcement manually.
try making pattern live load factor to 0.
sir , you were very much right . I got a normal pattern of my results.
As it is confirmed from CSI ETAB (When nonzero Pllf is assigned to a frame object, positive design moments are calculated assuming a simply supported condition under live-load application. While this does affect design moments, analysis moments are not affected)
 https://wiki.csiamerica.com/display/kb/Pattern+live-load+factor
  • 2 months later...
AOA !
How to decide the Pattern live Load Factor value. In ETABS 2013 it is 0.75 by default....
ACI Code 13.7.6. provides answer to your question.
The program would consider design moment using PLF only if the value of design moment is > than analysis moment, else it would just design for analysis moment.
AOA !
It depends on engineering judgement, for example i will quote the example my professional (Col. Iqbal) gave me;
If there is a barber shop and adjacent to that is the heavy storage area, then this is load pattern problem.
The factor will come from the understanding and feel of the problem.
