Failure In Shear Wall
Dear How r u designing the shearwall in shear?
If shearwall is failing in shear then you can do following things as told by Mr. Umar
1- Try to increase the length of shearwall. The thickness increase will not matter too much. But if you can increase length that will be helpful to design shearwall in shear.
2- Try to increase the shear reinforcement in shearwall.
3- Try to increase fc'
4- Try to add some more shearwalls to reduce the total shear demand by structure.
I think by these points of these four points you will be able to solve the issue because everything depends upon the shear force in shear wall.
You also need to provide confinement in the confined zones as well for flexural reinforcement.
Muneeb
One thing that I learned while dealing with above mentioned building is that area of the floor has significant effect on structural system to resist seismic loads. The building, under discussion, has an area of about 45000 sqft/floor. The building is 4 stories, the bay length is 26ft, the column size is 30 inches, and beams are 15x30 inches. Even then, one requires shear walls of about 130 ft length in both direction to satisfy strength and serviceability requirement of code.
The shear in one wall exceeds the maximum limit set by the code if one uses lesser shear walls.
The problem is base story shear, which is about 5000 kipps at second level.
Dear Baz
Just a discussion
You are almost right. Area does not matter too much to resist the seismic. The main area which resists is adjacent to shearwall. If area goes on increasing the Mass source is increasing and this increasing the lateral forces.
Secondly, Column will not contribute too much as these have small dimension along x and y direction. Mainly shear force is resisted by shearwall. For example x direction shear force is resisted by shearwall along x direction and y direction shear is resisted by y direction shearwall. Because we do not design the shearwall for out of plane bending. In shearwall shear design the depth used for design is the length of shearwall. so thats why by increasing the thickness of shearwall you can not satisfy the shear in shaerwall. For this you need to increase length.
Same is the case with beams. In beams if you increase the width of beam, it will not change your Time Period significantly but when you increase depth, it will contribute more.
If Base Shear percentage by weight is more then every force will be more. For shear this can be satisfied by increasing either no. of shearwalls or by increasing the length of shearwall..
Muneeb
Dear Baz
Just a discussion
Muneeb
The stiffer you make, the fun it gets!
