Design Of Footing In Safe
Goher Ahmed
Hi All
I am designing a footing for pre-engineered structure and mainly wind loads govern in such scenarios. Before I was using MAT 3D for footing design but now I want to design the footing using SAFE. I just want to know that how to apply wind loads to the footing and what about the horizontal forces that are coming. Should I have to convert them into moments by multiplying the horizontal reaction with the Depth of footing (vertical distance from top of the pedestal to the footing base)? Secondly, how to check the adequacy of the footing in SAFE and uplift???
I dont know about the wind loads. but you can check the adequacy of footing by clicking on reactions, and selecting the load case. if you want to check for bearing capacity, select the Soil pressure as type of reaction. But you must assign the soil supports to the footing by defining soil subgrade modulus.
Dear Goher,
If you are using prestress or pre-engineered columns, then in that case how you are going to connect the columns with foundation. If you provide some cast inplace pedestals then you can assign horizontal loads on them in addition to vertical loads. This will solve your problem.
Muneeb
Hello Goher,
You are right most of time wind loads govern but in case of Mezzanines, Seismic forces may govern also.
You are absolutely right. You will have to multiply horizontal forces with the depth of footing to get moment which you will have to apply at centroid of footing. If you want to check bearing pressure and strength design of footing, you can use SAFE but according to my knowledge, SAFE does not offer SLIDING, OVERTURNING check and for uplift, you may check pressure and pressure will tell you whether there is contact between your footing or your footing has been lifted.
To apply loads in safe, you can either model a footing slab and manually assign loads at centroid (by drawing a point or by meshing footing) or there is a better way also. You can import the whole base with reactions from SAP/ETABS to SAFE.
Moreover, I m attaching excel sheets which I have made for simple calculations of isolated Footings. You can use it. If you find any error, kindly report me back. I have tested them many times. These are a little rough but i think usable.
footing reinforcement design sheet.xlsx
footing sizing sheet.xlsx
But if you have slab on grade in your building, You can put a hair pin around the top of pedestal then the top of pedestal can not bend under the action of horizontal force in such case you will not have to convert this force into moment. In such case, you will have to design that hair pin to dissipate horizontal force.
