What Is Load Size In Csi Safe Footing Design?
Beenay Shahi
Please help me in understanding what is load size in csi safe footing design. What data should i input in load size?
Load size is size of column from which load will transfer to footing. In safe, when you mark a slab and draw a point or you start your model from template, in both case you need to tell about load size i.e. contact area of load with footing slab. This load size dimensions will be used in checking punching shear, cantilever length etc.
  • 7 months later...
