Drop In Slabs
mhdhamood
Dears ;
THANKS FOR EVERY MEMBER IN THIS GREAT FORUM WHO SPENDS HIS TIME O GIVE ANSWERS. MAY YOU ANSWER MY ISSUE
1.in fig.(drop2) ;can the drop in slab be like shown exactly or it is preferable to be over column exactly,and why?
2.fig.(drop in slab); can the drop also be at the midspan?
3.  how to account for the drop in desgin ?what is the considerations to take? I mean it will give additional weight .
4. Is there an obligatory locations for the drops?
5. is the detailing of steel fine to account for the stresses and development length? may give expanded discussion please.
6. To what difference in level between two slabs can we use this section as attached and how to guess the (x and y) dimenions?
post-1776-0-94617100-1446023403_thumb.pn
post-1776-0-79388000-1446023404_thumb.pn
Normally drop is provided in slabs to reduce the amount of negative reinforcement in slabs over columns, or to reduce reduce overall thickness of the slab. In such a case, the drop must be centered on the column, as per relevant code provisions.
The slab position, visible in your attached images, reflects the situation where two nearby slabs exist in such a way that one slab is at a slightly higher level than the other. Moreover, lower slab is a cantilever, acting as a support for the free edge of of upper slab. In such a case, drop may be at any location, provided it is properly designed structurally.
If you don't have any support at the end of drop zone then the slabs should be designed as cantilever (but do provide bottom reinforcement too). For simplicity, you can consider one slab resting on another. This design approach addresses questions related to both figures.
Just to add,
There could be drops in any shape or at any location in a slab, you just design for it.
The effective depth will increase ofcourse for thicker slabs.
I would preferably not design such slabs as cantilever on supported by the other slab, rather I will design it as continuous.
The portion where two slabs meet, I will consider it as beam and provide side bars for torsion.
I would also design it as a continuous member. The ability of this member to tranfer moments across drop will depend upon detailing, and the sample detailing in the picture does not seem adequate; there should be a  double bend (u-shaped hook ) instead of the standarad L shaped.
Here are some additional points for further consideration.
For the case of flat slab (like the one shown in the picture by Shaker) even if the "drop zone" creates a beam, the beam wouldn't provide the necessary action because of lack of any support at its end. I will try to sketch up something and post it to explain my point.
In addition to that, the drop portion cannot  be casted as one piece.  The bottom slab has to set and harden and then the top portion can be poured.
