Temperature Gradient
mhdhamood
friends:
What are the temperature gradient for slab in dubai?
someone suggest to put change in temperature at top face 50 c
                                  and  change in temperature at bottom face 25 c?
shaker,
IMO, you should check values of maximum outdoor and maximum indoor temperatures for Dubai, from the internet (or some other authentic source), and use them for the top and bottom faces of the slab, respectively.
Alternately,  'Record high' and 'Record low' temperatures from the following source, may also be used for the purpose :
https://en.wikipedia.org/wiki/Climate_of_Dubai
