Load Path Calculation
Muhammad Umar
Please share the structural framing plan of the house that shows the location of beams/ walls and columns(if any).
The load path is generally:
Roof or Floor -> Beams or Walls -> Foundation.
For masonry, lower story walls have more load the higher story for obvious reasons.
Surely, i missed out with few of the Architectural plans needed for the calculation of the load path. I have modified my post above with the plans added to the section attached. Mostly, double brick walls are used for exterior  with interior walls mostly made up of gyprock.  Dimensions used above are in mm.
Please also recommend some resource/ reference, that would be quite helpful in understanding the load behaviour.
Can you post your structural framing?
As the project is going through the preliminary design phase, and no detailed structural analysis has been carried out yet, so therefore i am unable to provide you with the structural framing plan at the moment. The architectural plans were attached just to facilitate further in this regard about how to make certain assumptions for structural components on the plan.
omar,
Load path for a structure is decided by the structural engineer, and it depends upon which kind of structural system, he or she (the structural engineer) selects for the building under consideration, in order to properly transfer the design loads from the slabs to the ground.
Generally speaking, there are two types of structural systems you may adopt for your building; a load-bearing wall system, or a moment resisting frame system.
In load-bearing wall system, your gravity loads are directly supported by slabs, resting on load-bearing walls (or isolated beams, provided to divide larger slabs to suitable size smaller slabs, for economical design of slabs). The beams, if provided in this system, also transfer the slab loads to walls, which in turn transfer these loads to the footings, resting on ground.
In this case, your load path will be: Slabs to Walls (or beams, if provided),  Walls to footings & footings to ground.
On the other hand, if you opt to adopt a moment resisting frame system, the slabs will transfer loads to beams provided along the slab edges, beams will transfer loads to columns (instead of walls) and the columns (rather than walls) transfer the loads to footings, to be finally supported by the ground.
In this case, your load path will be: Slabs to beams, beams to columns, columns to footings & footings to ground.
