Etabs Defining Concrete Material Property Problem
haro0n
salam i have problem related to defining concrete material i have attached the image. its shown there that mass per unit volume of concrete is 2.24 and weight per unit volume of concrete is 8.68 while the units are kip-in. and fc'=4ksi. i want to know how both these value comes?? and if fc'=3ksi then what will be the values of these two?? i-e mass per unit volum nd weight per unit volume???
change your units to lb-ft
as you know concrete density is 150 pounds per cubic feet = 150 pcf
now w=mg according to physics...and g = 32.2 ft/s²
so your mass will be = 150/32.2 = 4.658 lb
remember to check your units....if in your case it is kip-in then
weight = 150 lb/ft³ / 12³ / 1000 = 8.68E-5 kips/in³ (not just 8.68 as you mentioned in your question)
similary mass = weight / gravity = 8.68e-5 / 386.4 = 2.246E-9 (because 32.2 ft/s² = 32.2x12 = 386.4 in/² as your units are kip-in)
weight and and mass are not affected by compressive strength....
thanks alot sir u solved my problem :) i was confused with it. took help from internet but it confused me more so i posted it here :) thnks for it :)
