Steel Reinforcement For Openings Like Doors In Rcc Walls
shani2k2
Your wall vertical reinforcement will end where the door starts. It should be terminated as standard hooks. Where you will have door opening, your horizontal wall reinforcement that will interfere with door opening will also terminate as standard hook. You can provide vertical bars (like column reinforcement) around the doors. That should suffice.
