Over Reinfoced Beam Check
Nasir Malhi
AFAIK, ETABS (& probably SAP2000 as well) indicates required reinforcement ratio, in cases where it is less than maximum steel ratio. Otherwise, member is marked as 'O/S #2 ', indicating that the required reinforcing is more than maximum steel ratio. However, required reinforcement ratio is not output by the software in the later case.
This is in line with general practice (especially in case of columns) that actual amount of reinforcing steel is kept below 50 percent of the maximum permissible steel ratio, in order to facilitate splicing of reinforcement at different floor levels (where actual steel ratio will be doubled due to lapping of bars).
On the other hand,  in case of beams, required area of steel given by ETABS might be more than maximum steel ratio. Whether the required reinforcing is less or more than the maximum permissible steel ratio, has to be checked & verified by the designer himself, manually or through a purpose-made spreadsheet.
  • 2 years later...
Etabs Doesnot Fail beams in Flexure normally..... Even sometimes it go beyond Rho maximum but at the same time it adds same amount of additional reinforcement (over Rho maximum value) on the opposite face of beam to maintain ductility behaviour of beams.... this what i have observed... anyone is open to comment.
