Etabs 2015 Analyzing Problem, Please Help!!!
kemal
Hi everyone from turkey,
I have a problem with etabs 2015. Sometimes the programme is freezing during analyzing. To solve the problem, I have to move the .EDB file to a different directory. İf I do this, analyzing is done. Have you ever came on with the same stuation? please help. Here is a screenshot which shows the problem. Thanks a lot...
post-2215-0-96765900-1456060804_thumb.jp
It is something to do with your storage drive as you said, if you move it to another location it works fine.
Also check security/scan settings for the drive in which you are working. Is it interfering/accessing the same files as ETABS does?
Not exactly this but I have come across "failed to retrieve joint" errors sometimes when I run directly in our office servers. So I save it on my local pc and run and then save back to the servers.
