Beams and Columns Over-stressed Next to Shearwall
asadishaq
Dear All Experts,
Can we provide hinges in the columns at top and bottom? I am asking this question in a scenario that my columns are very close to shear walls and are getting  very high moments.
Dear Umar Bhai,
These are the concrete columns,I want to know how should I detail these columns if I provide the hinges in ETABS at top and bottom of the columns.
The only detailing that comes to my mind to achieve the aforesaid is to provide a steel section between length of concrete column that allows hinge behavior. However, that might be a construction nightmare as you will need to use embedment plates. So from a practical standpoint- if your system is a dual system, your  frame (columns+beams) should be only resisting 30% (or 35% I don't remember exactly) of the total base shear. So you can have two separate models (like you will have for any dual system analysis) and check that condition. If they pass  then you should be fine as that is the minimum required strength that your columns need to meet.
