should strap beam be monolithic with the isolated footing?
Beenay Shahi
Although bottom levels of the strap and the two connected footings are generally not the same, and strap bottom level is a bit higher than the bottom face of the footings, the strap beam has to be cast monolithic with the footings. For further clarification, please see Example 16.4 (especially the last paragraph) related to the design of a strap footing according to ACI 318, at the following link
http://www.chegg.com/homework-help/complete-design-strap-footing-example-164-determine-dimensio-chapter-16-problem-6p-solution-9780073293493-exc?adobe_reloaded=true:
