moment of inertia at slab-beam-column connection
AOA,
According to ACI 318-11 R8.7.1 stiffness to be used for braced frames should be EI/2 for beam members and full EI for column members. Also the code mentions the stiffness increment factor of 1/( 1- c2/l2)^2 for beams for the segment starting from column center line to face of column. In equivalent frame method of 2 way slab design, it also mentions that moment of inertia of column from mid of slab to bottom face of adjoining beam be taken as infinite.
Now based on above provisions, should I typically model the joint as rigid uptil beam and column offsets? Another option i was thinking was to model the joint in separate segment and assign stiffness factor to that segment only. But it seems a pretty cumbersome process.
Should I be modelling both the rigid joint connections as well as assigning reduced moment of inertia factors to the rest of the member regions?
thanks for the support
Quote
R8.7.1 — Ideally, the member stiffnesses EcI and GJ should reflect the degree of cracking and inelastic action that has occurred along each member before yielding. However, the complexities involved in selecting different stiffnesses for all members of a frame would make frame analyses inefficient in design offices. Simpler assumptions are required to define flexural and torsional stiffnesses.
For braced frames, relative values of stiffness are important. Two usual assumptions are to use gross EcI values for all members or, to use half the gross EcI of the beam stem for beams and the gross Ec I for the columns.
For frames that are free to sway, a realistic estimate of EcI is desirable and should be used if second-order analyses are carried out. Guidance for the choice of EcI for this case is given in R10.10.4
W/salaam,
The answer is in the commentary. Please see the highlighted text in the quote. Keep it simple.
