RCC Wall Axial Load Carrying Capacity
Ali Shan
Assalam-o-Alaikum,
I have modeled a retaining wall in SAP2000. I have got the moments are shear forces in major and minor directions. The wall is also carrying some concentrated axial loads over it (separated at some distance). My question is, how can I check the axial force present along the length of the wall in SAP2000? Like M11, M22, V12, V23, which component denotes the axial force transferred? Also, please give some reference of calculating RCC wall axial load carrying capacity.
In ETABS, SAFE, SAP axial forces are F11 and F22 in 1 and 2 directions resp. By default axis, a load applied in elevation to a wall will show axial force as F22. You can sumup/average total axial force by assigning it as a pier width of which depends on the length, spreadout and type of applied load.
Axial capacity of wall as mentioned in above reply can be calculated like a column. You can calculate capacities of anything from PMM interaction (atleast for a beam, column and a wall). Just respect the boundary conditions.
