Shear failure of structural walls
Badar (BAZ)
Can shear failure of structural walls trigger collapse of reinforced concrete building if the building satisfies drift limits and its frame can independently take 50 percent of seismic force in both directions.
If shear demand of structural wall is more than the capacity due to seismic forces, and if the frame can take fifty percent of base shear, satisfying the drift requirement for that 50% share, then can this lead to the collapse of structure.
So another way to put the question would be: what would happen if shear wall is under-reinforced in a dual system? How would the frame behave? What would be the limit state?
This is a tricky question as the analysis technique requires frames in dual systems to be independently checked for X% (50% I guess but don't remember) of base shear. However, the lack of ductility in shear wall would result in loss of stiffness, and the frames would start to pick up as soon as the wall cracks.
Its hard to predict what would happen as there could be a number of scenarios.
