ETABS modifiers issue
Elie Saadeh
Hi, i am a fifth year student working on my final project, it is a 59 floors +  basements tower.
I am having a weird problem; after applying the stiffness or property modifiers (0.35 for beams and walls, 0.7 for columns and 0.25 for slabs), i got an instability warning during analysis. After several trials i found out that the problem is from the modifiers of the slabs, the other elements don't give me any warnings.
So i tried to change the value of the 0.25 modifier and increased it to 0.35 (or higher) and after that i didnt get any warning messages.
Is it normal or logical to get an instability warning below a certain value for a property modifier? or there is another problem related to something else and appears when i do this adjustment ??
i still cant use the 0.25 modifier for the slabs (for m11 m22 and m12).
Any help is appreciated a lot. Thanks.
Are you sure its just the change of modifiers that stopped giving errors? I never came across this. Are you sure you are not out-of-plane modifiers to membranes?
I want to ask if we should give modifier for sections like shear walls, columns, ....etc or leaving as it is ,please I want some explanation about this because I have two high rise building and I need some information about them and if I assume my slab as a rigid diaphragm this affect on it or not
  • 3 months later...
  • 3 months later...
