designing foundations for the critical load combination
mhdhamood
Dears;
If I have let us say 20 load combinations for loads on a single footing or combined, then the best way to design and check stability will be; cheching for every load combination seperately one by one.But also its time consuming
So What do you suggest in load combinations for stability checks(sliding, overturning and bearing) and designing?
On 6/5/2016 at 6:18 PM, mhdhamood said:
Dears;
You need give it a shot. Think about it...
For stability checks you need maximum moment..right..Now think about what combo in your case gives maximum moment.
Also for the shear in case of sliding...There wont be many combinations that give you maximum results.
Try checking by contours for example if you cant judge.
