MODAL PROJECT
Hussain Abid
Aoa dear experienced fellows. Im working on an 8 story building inzone 2B soil type sd in UBC97. Using static procedure i get the building design ok bt to me the problem is that basement n ground column gv more than 5 to 7% of As. Is this much As ok? Or shud i provide perimeter shear walls or only basement walls? Though the building is safe wrt max drift n story shears etc. Kindly suggest wats to b done in this regards.will there b any difference by modelling stairs n elevators in the building as still i hv not done so i hv just designed frame so far.
Best regards
Edited by Abid Qasmi
WAA.
From field point of view, it is better to keep the column reinforcement percentage to about 50% of maximum allowed by the code, as in the normal practice column main bar splicing is mostly done at one location, and at that location actual bar area would be doubled & it must not be more than the maximum permitted by the code. However, splicing may be staggered as well in compelling circumstances.
I order to limit reinforcement percentage to desired level, you may need to increase the column sizes in the affected floors, or add shear walls at suitable places.
You will need to model elevators to act as shear walls. Some people model stairs as well. I don't model stairs normally.
