Unable to apply line loads on concrete slabs in ETABS and SAFE
spatio99
I'm designing a flat slab structure with perimeter cladding that is to be anchored to the edges of the slab. The external cladding has a total weight per meter run of 5 KN/m. How can I apply this load to the slab edges so as to model the true behavior of the slab under loading in order to get accurate results from the analysis?
You may provide dummy line members (beams) along the slab edge in your ETABS model and apply cladding load to these dummy beams.
For a better distribution of loads, slab should be meshed suitably, and the the dummy beams should also be divided along the relevant joints of the meshed slab.
After analyzing the ETABS model, the slabs may be exported to SAFE, if required.
