Torsional irregularity of Buildings using etabs
chasm9a
is there any need of shear wall to the top-left side of this building since the elevator shaft is lying at one side of the building and the building will undergo a torsion.
if we need to provide shear wall at some other location, please mention it.
please clearify, how can i check the torsion of this building in etabs?
Hi Chasm9a,
You can have a look at discussion below that allow you to show  "Story Max/average displacement -----> ratio value" from ETABS to verify if minimum torsional eccentricity needs to be increased or not. In other words, it would also tell you if you need additional shear-walls.
As far as your current framing goes - without knowing any building information- I would provide a shear wall (If North is up, then the shear wall would be in East West Direction) in all the three corners where there is nothing right now.
Thank you @Rana @UmarMakhzumi
I found what I was looking was for. The building did had a torsional irregularity and (north is upward) north-south wall length was increased by 6' and south-west wall still remained 7'. Calculated drifts as per UBC 97 and brought the drifts within their limits.
Thanks to this forums as we have all have been learning a lot from it.
I am sorry for misunderstanding. Torsional irregularity information cannot be checked from the tables you provided above. What I meant was overall dynamic performance of the building looks okay from the numbers.
However, I am glad, you found the solution. :)
@UmarMakhzumi
The building is Basement+ground+2 floors. Basement will be used for parking.
The south-east corner has a projection at 1st and 2nd floor. Shear wall could be provided only on north side of the building. South side has basement extended upto 40' more. and there are no walls in the basement but a parking. The architect provided the elevation-shaft at wrong location. I discussed that with him but he said that the plan was approved by client and it cannot be changed.
Here my question now is:
Just like umarMakhzumi said: shear walls have to be provided on all sides of the building, so is it necessary. I have balanced the torsion of the building and clearly it can seen from animation of the building. Is it compulsory that I have to provide shear walls on all sides of the building? (mine thoughts about it is that no!)
6 hours ago, Rana said:
No, as long as there is a lid on drifts and irregularities.
9 hours ago, chasm9a said:
@UmarMakhzumi
You question has been answered. I will just add that make sure there are no future additions to the building in terms of stories. Talk to Architect and Client and if there are, make a model with future/ potential stories and recheck your numbers.
