See who gave reputation
There's nothing here yet
    • By Mehdi_
      As you know, we are forced to convert the ETABS results to executive drawings. This is a time consuming job. Is there any software that accept ETABS outputs and generate drawings? Specially for a reinforced concrete structure.
    • By Engr Waqas
      Assalam o alaikum,
      I was reading ETABS concrete frame design manual ACI 318-08. In beam design section, it gives two formulae which I am unable to find in books. One formula for stress block depth and one formula for negative steel calculation. I have highlighted the formulae in below images. The manual design using these formulae and conventional formulae gives the same result. But kindly guide me from where I can get derivation of these formulae or theory behind this.
    • By Meesum Zaidi
      I m  currently analysing multi story building on Etabs, I need to apply 4 and 6 inch wall load and would like to know how that can be done.
      in this building maine no load bearing 4 inches and 6 inches ki walls use kari hain load assign kaise hoga walls pe ye samajh nhi arha line load apply karun ya area type load please help
