Positive Moments at supports-is this alright?
Ussama Waseem
I am just starting with the structural design using ETABS. So that makes me curious if something unusual happens. I have attached a screenshot of my analysis of a beam. It shows that I am having positive moments at support from one side of a support, whereas negative at the other side(which is usual) for the governing design combo. I am just unable to perceive positive moments at support. Just posting it so that members can help me if this is usual or have I done something wrong while modeling. Looking forward for responses.
Analyze a 3-bay planer multi-story frame with beam lengths twice the column lengths. Make the gravity load zero and apply a UDL horizontal load on left most columns all the way from base to up. See what is the bending moment of beams and then read chapter 3 of Reinforced concrete design of tall buildings by Tranath. It will help.
It can happen when lateral loads are included in combinations. Stresses of reversal due to lateral loads causes any side of joint in continuous beam to have tension on lower side causing positive moment at support on one side. So check if ur combination is including lateral loads.
