Rigid vs flexible structures
Suveksa shrestha
Hello all
Can we say that if a building has heavy mass,it is called a flexible structure just because w=sqrt(k/m) meaning frequency is low and time period is high.it means the body takes long time to come to rest.if the structure is flexible,as the ground displaces,its base starts undrgoes large deformation,but the structure tries to remain static?does this mean,during earthquake of longer periods,the buildings fail due to large deformation of its base?in flexible structures,the acceleration at the top is almost zero,so earthquake acceleration is very negligible over its inertial mass,right? can you please explain,base isolator are required for flexible buildings? And please explain the response difference between flexible and  rigid structures,please enlighten me
Yes if you keep k=constant. That means for a given stiffness of a structure, higher mass would give higher T because the lower stiffness is unable to hold back the higher mass. Example: Tall buildings
I guess you are working with long period seismic waves on tall buildings? If so I have done masters thesis on the same topic. Not sure what you gonna achieve but here is an excerpt from my thesis;
Response of a building to ground displacement, velocity or acceleration depends on the
time period of the building. For example, the response of a tall building (time period of
more than 3 seconds) will be more sensitive to ground displacement as compared to
ground acceleration and velocity and is recognized in some building codes; for example
in Japan (Fédération internationale du béton, 2003, p. 94).
Excerpt from the thesis;
A rigid structure will vibrate as it is a part of the ground itself. A rigid building will
move with the base; however the upper portions of a tall building do not move with the
base due to the resistance of inertia of masses, and bend in many complex modes
(Taranath, 2010, p. 348). The mass at top floors remain stationary while the base of
structure moves with the ground (Taranath, 2010, p. 379). So the response of the
structure and the input acceleration loads are lagged. It takes time for the shear forces to
accelerate upper masses in a tall building depending on the stiffness and mass of storeys
(Carr, 1994) as is shown in following figures.
I have attached the relevant pages in this post. If you are working on the same topic I can share with you the whole thesis. Good luck.
Chapter-3.pdf
Hello ,
I am very grateful for your time on my topic.i would surely like to discuss with you regarding this topic if you can spare me some time.i will get back to you after 2 days now,cause m having my exam..and thankyou very much for your precious comments...i wish to have good discussion with you..i really need good suggestion regarding it
