Flat slab on planted columns
mhdhamood
Dear all
a flat slab in last floor is carried by too much planted columns that rest on a down flat slab without beams.
İ modelled it in Etabs , for th purpose of designing vertical elements.but for designing the flat slabs i export the model to SAFE.
in SAFE MODEL i dont do any modifeirs for vertical elements or for slabs ie all are =1.
Now in SAFE the flat slab rests on fixed columns with no settlement (the planted columns) whereas in reality there is a settlement in those columns (as in etabs model)
so shall i design the flat slab (the carried by planted columns)  by etabs or safe?!
Or there are any modifications you can suggest??
Yes, when you export to SAFE, columns will be fixed. You can do following;
1. In SAFE, change the fixation to springs, iterating several times for spring stiffness, until you get the same deflection under each column matching with those in ETABS. Quite cumbersome (almost impossible).
Also the SAFE deflections you would be comparing with those in ETABS are not compatible. In ETABS you modified the stiffness by assuming modifiers while in SAFE, the cracked inertia analysis is done based on section and reinforcement and moments.
2. So, the other option is to design it inside the ETABS. I guess in ETABS 2016 you can design slabs as well.
