Minaret Design
Rifat
54 minutes ago, Ayesha said:
It is the same as designing a column with a stair case inside it.
Thank you for your earnest co-operation.But this minaret is different its having diameter of 5' and 50' long and simply attached by a shear wall.
The biggest problem would be to control the excessive sway. The question you need to ask is if there would be any human occupancy in there/visiting deck etc? 99% chances are NO. There will be no human occupancy so limiting the sway & acceleration is out of the equation now. That leaves you with a sway limit of as high as 1/100 instead of usual 1/400 for buildings under service winds. You might need to pay attention to non structural components design for the drifts they gonna accommodate.
You can use section designer to model hollow column and can also create ramps for stairs using the extrude command. I think it is better to keep your model simple and exclude ramps whatsoever.
