Modelling Bearing Wall System in ETABS
mhdhamood
Dear Engineers ;
I have a building that it's lateral force resisting system is bearing wall system but i have several beams in some floors for several purposes like level differences and to refuce deflection .Now in ETABS I modeled the building  without these beams.but i considered the beams in SAFE.
Any comments, seniors??
Thanks in advance
Edited by UmarMakhzumi
Updated thread title to make it more relevant
Why are you modelling the structure in ETABS.
If you are modelling to know the seismic demand on walls, then you should have included beams, because you can't neglect the weight of beams as the weight effect the seismic demand. The weight also effect the time-period.
If you are modelling to find stresses in your bearing walls, you need to model these beams, as they will be inducing the point load on walls.
I am not sure how the slab is supported? Is it a flat slab? How many stories? Beam flexure also plays part in seismic resistance. You have to see what is your system and how much beams are resisting the lateral forces.
Just to add to the earlier point that If you have a wall system, the best way to get seismic demand is to model walls only, assign diaphragm and apply manually calculated seismic loads at each level. This would keep clutter out and you can also assign/ remove selected beams to see their impact on wall capacity.
