Waffle slab in Etabs
farooqbro
You can model an equivalent slab (simple slab with same weight as that of waffle slab). For that purpose, calculate the weight of a waffle by considering centreline between two ribs - calculate the weight of that section for a unit length. Then equate that weight to weight of a equivalent slab (same plan dimensions) and calculate the required depth. Another method would be to model in Safe and export back to ETABS. I haven't done this, just thinking out loud.
