Difference between tension controlled and under-reinforced sections
Abdul Malik Memon
Salam,
What is the difference between the under reinforced and tension controlled section? Are they same with the exception of strain values of steel.?
Many Thanks
Edited by UmarMakhzumi
Edited title to make the questions more relevant; added tags.
Great question.
Current ACI design (2002 onwards) is based on strain limit and based on that you end up with tension controlled or compression controlled sections. Tension controlled being the sections where strain is steel is equal or greater than the limit provided by code (0.005 I believe).
Previously (1963 to 2002), the reinforcement design was based on reinforcement ratios. This is where the terminology "under-reinforced", "over reinforced" and "balanced reinforcement" comes from.
The simplest word to put this is that any steel that has strain greater than 0.005 (or whatever the code says) at time of concrete failure is termed as tension controlled. Both under-reinforced and balanced reinforcement sections will meet this criteria.
ACI Code has not specified any stain-range for under reinforced beams. They just say that the beam should fail in tension before failure of compression region. By that definition, the tensile strain in steel must have a value of more than 0.002 before the compression strain in concrete reaches 0.003 for under-reinforced section.
