Building Joint Displacement/ Drift in Etabs
farooqbro
hope you will be fine
how to calculate building joint displacement from etabs specially for EQ loading  and what are the code allowable limits for that .?
Edited by UmarMakhzumi
Modified topic title to make it more relevant to the posted question.
After running the analysis, one way is to look for the symbol that is used for displaying the deformed shape of your structure. The deformed shape will be displayed against a load case, or load combination. Once you have deformed shape, right click on the node where you want displacements.
Limits are already discussed in the forum. Use the search facility, either on google, or in the forum.
