lateral dispalcement in Response spectrum analysis in ETABS
ILYAS
1-How to read in 1st mode/2nd mode lateral/absolute displacement of structure in ETABS?(FOR separation purpose)
2-When you go to command " story response plots" ETabs shows unreasonable results(very less) fo lateral displacement.(case/combo =modal, output type=mode and step number=1),is step number mean mode number?
3-While in print tables option you recieve lateral/JOINT/absolute displacement corresponding to only load case,but i am intersted in mode shape.(What is  lateral dispalcement of story in 1st/2nd and third mode?
mode shape displacements are not abs values. They are relative values compared to max value of 1.0. The max displacement is always 1.0 and then the others are compared to this e.g. 0.5 etc.
You multiply this modal amplitude values. Solve one mode shape by hand of a 2 storey frame you will get it.
Anyway for separation, see it on response spectrum case or combination. For more detail you can combine modes as described in CSi ETABS Wikki help pages online. The topic is about accidental amplification of torsion in response spectrum cases. Look for that.
