SHELL ELEMENT RESULTS INTREPRETION
adilkhan
HI . i Do analyze shell element ( vertical wall ) and found its result as this . for dead load when i see F11 it show me below diagram with some valve positive and some negative. what that positive and negative means ?
is that tension and compression ? if yes so what sign used for compression and what for tension ?
Quote
F11: Direct force per unit length acting at the mid-surface of the element on the positive and negative 1 faces in the 1-axis direction.
F11 is what is defined above. You need to trun local axis on to see where is 1-1 direction is. Turn it on and and share the picture here.
F11 is axial force along local 1-1 axis. Negative is compression. Positive is tension.
22 hours ago, adilkhan said:
how dead load cause it . i means its kind of shear if i am not wrong
Gravity loads cause bending moment as you know it. Moment is nothing but a couple with opposite forces. These are F11. Multiply this with depth of beam (which is equal to distance between couple forces), you will get the moment at mid-span for example. You can verify by hand.
Shear is not F11..Shear is F12. Remember the basic cube with directions marked on it in strength of material course?
  • 3 years later...
For walls:
F11 in this case is along X axis. F22 along Z axis.
Local axes color code: RGB: red, green, blue for LOCAL axes of the shell
Red 1: along X
Green 2:along Z(white in case of sap2000) vertical
blue 3: Perp. to surface or Y axis.
Edited by shahidthanvi
cordially, for clarification,  (perpendicular to surface )shear is V23 for the walls.
F11,22,12 are in plane forces.
F22 vertical, f11 horizontal,
F12: seems in plane shear of shell elements like in finite element analysis.
V13: shear along x axis or horiz.
have a look at difference bw shell local axes and pier local axes, also global axes
