moment of inertia in shear walls
Wajahat
On 11/20/2017 at 1:36 PM, Wajahat said:
usually designer used uncracked section 0.7 value ...
pretty simple
check stresses in walls, if they are more than modulus of rupture they are cracked, use 0.35 otherwise they are un-cracked so use 0.7. Then iterate. Cracked walls will be in high rise with more seismic loads.
On 11/20/2017 at 1:16 PM, ILYAS said:
cracked section is must
See above.
On 11/20/2017 at 8:13 AM, EngrUzair said:
In this connection, you might like to have a look on this link that contains a very useful discussion on use of cracked sections in the stiffness analysis of reinforced concrete members.
thanks...sir
