Insertion Points for Shell Elements in SAP 2000
hali
Please see the article
Quote
Shell Assignment - Insertion Point
Use the Shell Assignment - Insertion Point form to define shell edge point offsets from Cardinal Points. For a rectangular shell object, there would typically be four edge points � one at each corner. However, a shell object may have any number of edge points (corners), and any of these points may be offset using this form. Prior to accessing this form, one or more shell objects of identical geometry should be selected. Use the Assign menu > Shell > Insertion Point command to access the Shell Assignment - Insertion Point form.
Cardinal Point
  • Cardinal Point drop-down list. Select a Cardinal Point location (Top, Middle, Bottom) for the selected shell object. Top refers to the shell surface which lies on the positive local 3 axis, Middle lies at the origin of the local axes, and Bottom refers to the shell surface which lies on the negative local 3 axis.
Joint Offset Options
  • No Joint Offsets - Delete Any Existing Joint Offsets option. When this option is selected, no joint offsets are used for the selected shell objects.
  • Joint Offsets from Cardinal Point at Selected Point Objects that are Corner Points of Selected Shell Objects option. When this option is selected, set the joint offsets for the selected corner points of the selected shell objects. In order for this option to be available, at least one corner point must be selected in addition to a shell object(s).
  • Joint Offsets Specified Point-By-Point from Cardinal Point option. Select this option to specify joint offsets on a point by point basis.
    • Point Number box. Use the VCR controls to move through the edge points of the selected shell object to find the point to which an offset should be assigned. The joint offsets may be different for each edge point.
    • Point Label; Point Unique Name box. This is an information box that provides the label and name of the point selected in the Point Number box.
Offset Coordinate System (Applies to All Offset Joints)
  • Coordinate System drop-down list. Select either Global or Local as the coordinate system to use when defining the joint offsets � this setting applies to all joint offsets. This drop-down list is not available if the No Joint Offsets option is selected.
Joint Offsets
For the edge point objects selected in the Joint Offset Options area, specify the joint offset in each of three directions using the following edit boxes.
  • Joint offset in {global X; shell object local 1} direction edit box. Enter the joint offset in the {X; local 1} direction in the units shown.
  • Joint offset in {global Y; shell object local 2} direction edit box. Enter the joint offset in the {Y; local 2} direction in the units shown.
  • Joint offset in {global Z; shell object local 3} direction edit box. Enter the joint offset in the {Z; local 3} direction in the units shown.
Do not transform shell stiffness for offsets from centroid for non-P/T floors check box. When this box is checked, the shell stiffness is not transformed to account for the cardinal point or joint offsets. Thus, the cardinal point and joint offsets are used for graphical display only. This option is applicable only for shells that do not contain post-tensioning � shells with post-tensioning will always have their stiffness transformed based on the cardinal point and joint offsets.
Reset Form to Default Values button. Click this button to reset all values on the form to the default settings.
Get Values from Currently Selected Shell Object button. Click this button to populate the Joint Offsets area with values based on the currently selected shell object.
Access the Shell Assignment - Insertion Point form as follows:
  1. Select one or more identical shell objects (as well as edge points, if needed).
  2. Click the Assign menu > Shell > Insertion Point command to bring up the Assign Shell - Insertion Point form.
http://docs.csiamerica.com/help-files/etabs/Menus/Assign/Shell/Shell_Assignment_-_Insertion_Point.htm
  • 2 months later...
I followed these points but there is no "Shell" under the Assign menu. I'm using SAP version 19. Is it possible they changed it? I can't find the cardinal points or insertion points anywhere for shells/plates.
  • 2 months later...
