Depth of Foundation
Shamim Ahmmed
The foundation should be deep enough that it rests on a competent strata. If you have a geotechnical report, the geotechnical engineer would have made a recommendation about minimum depth in it. If you don't have a geotechnical report, generally it is kept below frost with assumption that the strata underlying the raft is competent.
4 hours ago, Shamim Ahmmed said:
what should be the minimum depth(D) of foundation?
It generally depends upon soil bearing capacity & will be recommended by the geotech engineer in soil investigation report (SIR) of a particular site.
In case of non-availability of SIR, even for some nearby site, IMHO foundation depth should not be less than about 3 ft.
  • 7 months later...
a soil report was investigated when water table at depth of 1m,during construction water table raise up to NGL due to seasonal canal runing excavation of foundation is deeper than water table will cause seepage of water in excavation my question is bearing capacity and shear properties of soil  is same in this condition, we can not provide footing at required depth any recomendation
You should create a new topic instead of posting in a totally irrelevant topic.
To answer your question, go for deep foundations like piles.
