Auditorium Design
Hamza Ahmad
Hamza,
It depends on some factors like cost, unsupported span and asthetics. Like if the ceiling is exposed, then Waffle is the go to slab type as it looks beautiful and can span large distance. If ceiling would be covered then you can go with literally anything. So do some preliminary designs, estimate the associated cost, talk to the architect and then propose an economical solution considering all the factors to the Client.
On 2018-03-14 at 12:43 AM, Hamza Ahmad said:
is waffle slab system should be used if the unsupported length in the X direction is almost 135 feet??
If it is designed properly, yes. What that means is that your slab needs to meet strength and serviceability criteria. You can model a waffle slab in SAFE and check if its reinforcement requirement and deflection are under code permissible.
