Expansion joint in etabs model.
Hamza Ahmad
It would be better to include the different portions of the building, separated by expansion joints, in a combined model as well, in order to study the behavior of structural elements located adjacent to expansion joints.
For this purpose, the members (columns etc)across the expansion joints may be connected through provision of a strip footing or a raft.
On 4/18/2018 at 3:05 PM, Hamza Ahmad said:
Aoa members.
if there is an expansion joint in a building so should we model them all together by dividing the expansion joint portion or should we model them completly differently  in etabs ?
Completely different models. There's no point modelling them in same model.
Modelling of different building portions in a single model might be necessary to safeguard against seismic pounding of adjacent building portions, in certain conditions (e.g., different heights, varistion in stiffnesses, insufficient gap)
More details, regarding pounding effect in buildings, are available at the following Link.
Not able to watch YouTube right now but will check. Are you talking about non-linear EATBS or other software? Because gaps and pounding etc. cannot be visualized atleast in linear version of ETABS.
And I fail to understand why to have all this hassle just for seismic pounding? It is very easy to calculate seismic pounding manually that is SRSS of inelastic displacements of both towers. If the heights are different, you calculate at that particular level. Been doing this all the time.
Or is there something crucial I am not able to grasp here?
What I know and found in few examples of modelling two buildings together is the mode shapes, dynamic properties etc. are misleading. I am not sure about the 'Tower' option (haven't explored in detail), but this is what I observed. The only benefit I see people modelling two towers together is for the ease of 1 joined foundation model (at the expense of wrong analysis results???)
Having a joined one foundation of multi-buildings in SAFE is not that difficult from different ETABS models. You just need to play with import-export or macro stuff.
Could you elaborate on this on how to combine different ETABS models f2k files into 1 safe fdb file?
  • 4 weeks later...
You have to make sure, load cases, section properties etc are same in both etabs models. Then export both files one by one to SAFE and import in SAFE. There is one caveat however if there are spectra loads present in ETABS. In that case, you will have to make sure that importing acceleration data is matches from 2 ETABS models to 1 SAFE model.
