Water Tank Bottom Slab Main Reinforcement
How the main reinforcement in the bottom slab of a water tank is placed ???should it be bent down at the ends just as the one bent up in room slabs?and do the temperature bars be placed below main bars on the soil side or above the main bars on the water side???
It depends on aspect ratio of slab, span length, and geotechincal conditions.One may require main reinforcement in both directions, as empty situation also needs to be considered( bottom slab loaded by soil pressure due to self weight of slab / water pressure if water table is high).
Direction of hook (upside or downside) does not matter,hook is for anchoring( in case bond fails).
Edited by baz
mistake
thanx baz n umar!!!@umar for bent down i mean just like the bent up as bars are bent up in the slab of room at ends bars are bent up at the ends to resist negative moment as im told that in UGWT bottom slab bars are bent down at an angle and then straighten to the end.
