Stocky Column!!!
where you heard/read this term? In Pakistan we use US codes and they use the term short column.Strength of Short/stocky columns is governed by the material strength of cross- section and is not effected by the length of column. Though local buckling might occur in steel columns.
Then there are slender columns whose strength depends on ratio of length to radius of gyration of section.These columns buckle under compressive loads before material strength of their cross-section can reach.
A column is essentially a vertical member designed to transmit a compressive load. Being a compression member, it is reasonable to suppose that a column would fail by crushing of the material when the load reached a high enough value, but for most columns failure occurs at a lower load than the crushing strength; this is because most columns are relatively slender, i.e. they are long in relation to their lateral dimensions which are termed as stocky columns. It is generally seen that when a slender member is loaded in compression, as for example when a slender garden cane is leaned on rather heavily, it will bow sideways or buckle, and if the load is then increased further the cane will eventually fail in bending.
If, on the other hand, a stocky column is used, one with a low length to breadth ratio, then a crushing mode of failure is more likely than a buckling mode. For example, if a block of timber 50 mm x 50 mm x 100 mm high were loaded in compression, one could not imagine it failing by buckling.
Thus the normal compression elements, length and lateral dimension play a part in determining the mode of failure that will result. Also, for a given section, there will be a critical length of the compression member below which it will be crushed and above which it will buckle.
The shape of a column is also very important. For example, a sheet of cardboard has practically no strength as a column, but if bent to form an angle section or other shapes as shown below, it is capable of supporting a load post-733-0-99712300-1341031017_thumb.jpg
It follows that by intelligent use of available material, economical columns can be constructed.
Buckling of slender columns and struts
If a long thin flexible rod is loaded longitudinally in compression, it is noticeable that it deflects readily near the mid point of its length with a considerable amount of displacement.
The phenomenon is called BUCKLING and occurs when the stresses in the rod are still well below those required to cause a shearing type failure.
However, if the length of the rod is gradually reduced, whilst still applying the axial load, a length is eventually reached below which the rod will not buckle. Its failure will be internal. I.e. material failure rather than structural distortion.
Columns and struts may therefore be described as either SHORT(stocky) or SLENDER depending on its mode of failure.
A short column or strut will fail internally by yielding in the case of ductile materials, such as mild steel, or by shearing in the case of brittle materials such as concrete.
A slender column or strut will fail by buckling, where a relatively large bending distortion will develop along its length. The member does not collapse immediately but remains in bent equilibrium unless the yield strength of the material has been exceeded.
The buckling phenomenon is an example of unstable equilibrium, whereas the behaviour of a short strut is that of stable equilibrium.
The axial load to cause buckling is called the critical load (P). For a given load, a critical length may also be deduced. In the case of slender structural columns or struts, the critical buckling load and the critical length depend upon a number of factors, such as the shape and size of the cross-section, the relationship between the length of the column and its lateral dimensions and the degree of fixity at both ends.
For a strut of given length which is pinned at both ends, the minimum load at which buckling will occur may be determined using a mathematical analysis which produces what is known as the EULER FORMULA. The Swiss mathematician, Leonhard Euler (1707 – 83), calculated the load at which a column would buckle if it were axially loaded and pinned at its ends.
Thus, the Euler buckling load for an axially loaded pin ended column is given by:
PE = the Euler buckling load
E = Young’s modulus for the material
I = the least second moment of area of the section
L = the length of the strut between the pinned ends
The magnitude of the buckling load given by this formula is the appropriate value for initially straight struts which are pinned at both ends and are subject to an axial load only. In the cases where one end is fixed and the other end is pinned, or where both ends are fixed, the effective length has to be determined by multiplying the length between supports by an effective length factor.
1. Both ends pinned Effective length = actual length x 1.0
2. Both ends fixed Effective length = actual length x 0.5
3. One end pinned
other end fixed Effective length = actual length x 0.7
4. One end fixed,
other end completely free Effective length = actual length x 2.0
Effective Length Constant Table
Column Boundary Effective Length Constant **C
Free - Free 1.0
Fixed - Free 2.0
Fixed - Pinned .707
Fixed - Guided 1.0
Fixed - Fixed .5
Guide - Free 2.0
Guided - Pinned 2.0
Guided - Guided 1.0
Pinned - Free 1.0
Pinned - Pinned 1.0
In practice, the assumptions of the Euler formula rarely hold good and some bending occurs in the strut, causing bending stresses. Also the initial straightness and eccentricity of loading are almost impossible to produce in practice with any reasonable degree of accuracy.
Therefore several empirical formulae have been developed for practical use. The Rankine-Gordon formula and the Perry-Robertson formula.
Perry-Robertson is the one most used but it is rather complex and so tables have been produced to assist the designer and these can be found in the respective codes of practice.
The safe axial load depends on:
A = area of cross-section
r = least radius of gyration of the section
Le = effective length (takes into account length and end
conditions).
The safe stress depends upon:
Slenderness ratio = Le/r
Where r = (I/A)1/2
I= moment of inertia
A= cross sectional area
If the slenderness ratio > (greater than) critical slenderness ratio, then the column is treated as a long column and the Euler buckling formula is applicable.
If slenderness ratio is < (less than) the critical slenderness ratio, the column is treated as a short column.
In short columns, failure may occur by compression without significant buckling and at stresses exceeding the proportional limit. For this condition, Johnson's formula is applicable:
For columns that fail subsequent to the onset of inelastic behavior, the constant of proportionality must be used rather than the modulus of elasticity (Engesser formula). The constant of proportionality, Et, is the slope of the stress-strain diagram beyond the proportional limit, termed the tangent modulus. Note within the linearly elastic range, E = Et.
Because of the problems previously mentioned with the Euler equation, the effective length factors are modified to take into account these practical limitations.
2. Both ends fixed Effective length = actual length x 0.7
3. One end pinned,
other end fixed Effective length = actual length x 0.85
4. One end fixed,
Note: These values for effective length factor apply to design to the current BS but may well vary in the new Euro Codes and thus reference should be made to the appropriate Euro Code for actual design values.
in the jammers reply at the end different end conditions are considered in 4th condition the effective length is the double of actual length this could make a sense plz explain how effective length is assigned actual*2.00???also in practical how do we consider that which side of column is free which is hinge which is restraining rotation how do we take this to actual condition in the filed???
For cantilever column effective length can be deduced by comparing with a pinned end column.
See attached derivation.
You choose end connections to column type based on how supporting members are connected to the column and what kind of connection you have. Connections can be moment, pin etc
Mechanics of Solids.pdf
I agree with sir umar the end behaviour of the columns depends on the type ot the member it is supporting and the pinned end column can be taken for the reference to deduce effective length of the cantilever column.
