Quote
jammer3425
Architects may interpret design as
being the production of drawings and models to
show what a new building will actually look like.
To civil and structural engineers design is
taken to mean the entire planning process for a new
building structure, bridge, tunnel, road, etc., from
outline concepts and feasibility studies through
mathematical calculations to working drawings
which could show every last nut and bolt in the
project that is why it is said that from where the
vision of architects ends the vision of engineer begins
zubaida apa k totkay safha paintalees line no 1
or yeh he aik akaam ki baat aj tak us nay ki hai
Some of the excuses we tell ourselves are:
  • I don’t know anyone who has done it before/ too many people are already trying.
  • I don’t have enough (money, power, skills, education, time)
  • If I was going to do it, I would have done it already.
  • I have too many responsibilities.
  • I am too old or young.
  • I will never be the best. Too many people are ahead of me.
  • It’s not the right time.
But, what if we simply rephrased these excuses into empowering beliefs?
  • It doesn’t matter what other people are doing, this is my dream.
  • I have more than enough resources to get started.
  • There’s no time like the present!
  • My number one priority is living passionately.
  • My age gives me a unique perspective, and is only a number.
  • There will always be someone to learn from.
  • It will never be perfect, so I might as well stop stalling and start now.
  • 4 months later...
  • 10 months later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
