Checking Analysis Result
haro0n
rana sir in this post
http://www.sepakista...-in-etab-model/
u said that
your base-shear is equal to about 5% of seismic weight which seems okay with R=5.5 and UBC 2B seismic zone
how to check that base shear is equal to 5% of seismic weight?
You dont have to worry about the magnitude as far as you satisify the seismic drift limits of UBC which are 0.025 and 0.020 times story height...based on time period of your building....remember to convert your elastic displacement values to inelastic displacement by mulitplying it to 0.7xR
after analysis it gives us elastic displacemnt nd we hve to check for inelastic?? and what is R here?
1) goto File>Print Summary and ETABS will report you V = 0.05W something like this....means base shear V = 5% of W
where W = effective seismic weight which is equal to the weight you put in mass source in etabs
to check W ...after analysis...goto Display>Show Tables...Select all load cases you put in mass source and show Story Shears
in tables> goto last story of model....you will see top and bottom of each story
just add all load cases P (axial load) at the bottom most story (bottom)...this is equal to your effective seismic weight you put in mass source dialogue box
note it down..lets say 1000 kip
now similarly show tables and see EQx and EQy in tables at the bottom most story..both values should be equal if your time period and R are same in both load cases..this is your total base shear in x and y...you can see this value from the graph by Display>Show Story Response Plots.. lets say 100 kip
So it means your V = 100 kips, W = 1000 kip
which means your base shear = 10% of your effective building seismic weight
2) study UBC chapter on seismic design or IBC or ASCE ...you will find what is R...R is response modficication factor of building system......
values of displacements or drifts in ETABS are elastic....but earthquake design goes into in-elastic range...so to convert your elastic displacement value you should first convert it into in-elastic values before checking drifts...(this applies only for seismic design...as wind displacements remain in elastic region)
in ASCE or IBC this 0.7R is equal to Cd/I where Cd is amplification factor for drifts in these codes..and I is the importance category...
UBC is obselete now....start studying IBC 2006 or 2010...or if possible 2012...you are young generation...follow the latest codes..with background of old codes..I will upload here the 2012 code soon
