How To Design T Or L Beams In Etabs?
Please check Page 66 of attached ETABS concrete design manual (not page 66 of pdf) that talks about beam design and also clarifies how T-Beams or L-Beams are designed in ETABS. You can normally model beams as rectangular and after doing the analysis, you can use the moments and shear values to design T-Beams or L-Beams manually. T-Beams are designed for +ve moment; because b is the width of beam in compression and that would be on top of beam supposing slab is on top.
Etabscon.pdf
The information given above is a bit dated with reference to both the ETABS version and the ACI code versions, as the above referred document pertains to ETABS version 7 and ACI 318-99. Whereas the ETABS 2015 & ACI 318-14 are the latest ETABS & ACI code versions in use today. (ETABS 2016 has been released a few days ago, however, AFAIK no changes have been made in it regarding present topic). As such, a little update correlating the previous & present situation, would be beneficial for all those interested. Here are my 2 cents:
1. According to ETABS Concrete Frame Design Manual, beam design in ETABS is done,
   a. As a Rectangular or T-beam, for the Maximum Positive Moment
   b. As a Rectangular beam always for the Maximum Negative Moment.
2. For ACI 318-99 and ETABS version 7, this is mentioned in 3rd paragraph under the heading 'Determine Factored Moments' on Page-37 of the reference provided by Ayesha earlier.
3. The same beam design principle has been followed in later ETABS versions (including ETABS 2015), for the later ACI code versions (including ACI318-14).
4. For ACI 318-02 and ACI318-05, this is indicated in Section 3.4.1.1 of the relevant ETABS Concrete Frame Design Manual, whereas for the newer ACI codes (2008, 2011 & 2014 versions), it is given in Sections 3.5.1.1 of the following ETABS 2015 Manuals for the mentioned ACI codes:
   a. ETABS Concrete Frame Design Manual (ACI 318-08)
   b. ETABS Concrete Frame Design Manual (ACI 318-11)
   c. ETABS Concrete Frame Design Manual (ACI 318-14)
5. Concrete Frame Design Manuals for the ACI 318-08 and earlier ACI codes, are generally installed along with ETABS 9 software, and are available in 'Manuals' sub-folder.
Edited by engruzair
Modified the text in S/No.5, for conveying the information correctly.
  • 4 years later...
    • I am designing a G+2 factory building founded on dense sandy soil as per our geotechnical investigation report.   Load considered:  (As Client was not sure about the purpose of use)  Live Load on Slab= 3.0 kN /m2 Dead Load on Slab= 1.5 kN/m2   (other then Self weight) Grid Spacing: 27'9"x21'3"  Plot Dimensions: 56'x165' Characteristic Load on Columns: (decisive case) Dead Load: 1900 kN Live Load: 950 kN The report recommended bearing capacits: Isolated Footing: 160 kPa at 2.0m depth  Settelment within 25 mm Raft foundation  300 kPa  at 2.0 m below existing ground level (EGL), With the column loads of around 2800 kN and grid spacing isolated footings would require very large foundation sizes leaving little or no clearance between footings and cause overlap issues. Therefore i decided to go for raft foundation.   However, the site condition is such that: The EGL (existing ground level) in the report corresponds to be the site’s current level +0.0 m, while the outer road level is about +0.9 m higher. Our finished factory floor will be at +1.5 m. Now i am evaluating two options: Option A – Construct the raft foundation at the recommended -2.0 m below EGL (per the GI report), then build up columns, cast a plinth beam at the raised level, backfill up to the required ground/floor level, and finally prepare a floor over the compacted backfill. Option B – Raise the site to match the road level using engineered, well-compacted backfill, and then construct the raft foundation directly at the new raised ground level, allowing the raft slab itself to serve as the factory floor. I want to understand: Which option is more technically sound and economical considering bearing capacity, settlement control, and long-term performance? Is placing the raft on engineered backfill (Option B) acceptable practice if compaction and quality control are ensured, or is it safer to strictly follow the geotechnical recommendation (Option A)? Any insights or experience-based advice on this choice would be highly appreciated. Furthermore:  Are the load assumed too conservative? Kind Regards Abdul Malik
