How To Design T Or L Beams In Etabs?
Please check Page 66 of attached ETABS concrete design manual (not page 66 of pdf) that talks about beam design and also clarifies how T-Beams or L-Beams are designed in ETABS. You can normally model beams as rectangular and after doing the analysis, you can use the moments and shear values to design T-Beams or L-Beams manually. T-Beams are designed for +ve moment; because b is the width of beam in compression and that would be on top of beam supposing slab is on top.
Etabscon.pdf
The information given above is a bit dated with reference to both the ETABS version and the ACI code versions, as the above referred document pertains to ETABS version 7 and ACI 318-99. Whereas the ETABS 2015 & ACI 318-14 are the latest ETABS & ACI code versions in use today. (ETABS 2016 has been released a few days ago, however, AFAIK no changes have been made in it regarding present topic). As such, a little update correlating the previous & present situation, would be beneficial for all those interested. Here are my 2 cents:
1. According to ETABS Concrete Frame Design Manual, beam design in ETABS is done,
   a. As a Rectangular or T-beam, for the Maximum Positive Moment
   b. As a Rectangular beam always for the Maximum Negative Moment.
2. For ACI 318-99 and ETABS version 7, this is mentioned in 3rd paragraph under the heading 'Determine Factored Moments' on Page-37 of the reference provided by Ayesha earlier.
3. The same beam design principle has been followed in later ETABS versions (including ETABS 2015), for the later ACI code versions (including ACI318-14).
4. For ACI 318-02 and ACI318-05, this is indicated in Section 3.4.1.1 of the relevant ETABS Concrete Frame Design Manual, whereas for the newer ACI codes (2008, 2011 & 2014 versions), it is given in Sections 3.5.1.1 of the following ETABS 2015 Manuals for the mentioned ACI codes:
   a. ETABS Concrete Frame Design Manual (ACI 318-08)
   b. ETABS Concrete Frame Design Manual (ACI 318-11)
   c. ETABS Concrete Frame Design Manual (ACI 318-14)
5. Concrete Frame Design Manuals for the ACI 318-08 and earlier ACI codes, are generally installed along with ETABS 9 software, and are available in 'Manuals' sub-folder.
Edited by engruzair
Modified the text in S/No.5, for conveying the information correctly.
  • 4 years later...
